Today I had to write up a long explanation as to why a drawing needed corrected. The production drawing had staggered pairs of contacts dimensioned from the right, the customer drawing had them and the mating board dimensioned from the left. When the customer ordered a part with an even number of staggered pairs, guess what? It did not match the customer drawings board layout. Lucky for the customer, they used the part to make their board.
How could this happen? Created dimensions.
Another drawing has a feature dimensioned four times in four different views, and not one is a reference dimension.
It takes a minute or two to redefine a part or assembly so that it matches your new design intent. You show all your dimensions and you don't get duplicates. Parametrics is great if you are willing to put forth a little extra effort to do things right. In the long run, problems are greatly minimized. You have robust models AND drawings. Yes, "AND drawings", since that is what a majority of businesses still use as the final say-so as to what is being manufactured. Doesn't that actually make the drawing just as important as the model? So isn't the drawing reflecting the model important? You do not get that with created dimensions, at least I have not noticed it over the 15 years of using Pro/E and mentoring other users.
The above is just two problems caused by created dimensions (and I have seen many), one that could have cost thousands of dollars to a customer in incorrect parts being made, lost time, and potentially lost business, and thousands of dollars to our company in either lost business or paying to correct the mistake. The other speaks of the sloppyness in drawings that do not even meet standards. Could there have been extra time and effort used in checking the drawings to make sure they were correct? Sure. Is this what we want to do every time there is a new drawing created? I wouldn't think so.
Isn't this why we purchased Pro/E in the first place...to be able to get to the market faster with fewer mistakes?
Yes, created dimensions are needed ON RARE OCCASIONS, that is why they are available in Pro/E. Otherwise I would feel better knowing that any Pro/E drawing or model I need to work on down the road is parametric with each other, saving me both time and money to make changes.
Joe Ordo
To: -Subject: [proecad] - RE: Shown vs. Created DimensionsFrom: -Date: Fri, 1 Aug 2008 06:30:34 -0700
I agree that there are times where you need to be flexible, but I always teach my users to use Shown dimensions as the standard and then use created dimensions if needed.
Shown dimensions will allow quick modifications at the drawing level that translate back to the model. This is why PTC created a Parametric Modeling System. Using created dimensions as your default practice goes against that principle. Remember that I said at the beginning that there are times where a created dimensions is needed for proper communication to manufacture the part.
Another reason I love shown dimensions is because it teaches the Engineer to think about how they constrain their designs. You want to constrain your features the way you would communicate the information in the drawing. This again will allow for quick modifications by anyone down the road.
Remember that at the beginning I stated that using a created dimension when needed is perfectly fine. I would never agree that using created dimensions as a standard practice is a good thing. Using created dimensions when needed addresses most of the reasons people claim they need them but using Shown dimensions as your standard practice will yield far greater benefits.
When PTC shows a new customer what makes Pro/E a great tool, I guarantee you they pull up a drawing to make modifications on it quickly and show you how this translates back to your design. You don't need to sit there and delete created dimensions or reference them every time a change occurs.
PTC did give you the ability to create dimensions because they are times where the design intent does not capture a particular dimensions needed by your manufacturing process and you can always use them to fill in the holes. I would venture to say that PTC would consider Shown dimensionns the standard practice with created being a good secondary option.
That is my $.10 🙂
P.S. Superman always wins. He is the only true Superhero. All others wear costumes to change to their hero state. Superman's costume is a civilian because he was born a Superhero not the other way around.
"If you are not living life on the Edge, You are taking up too much space"
