Simple LOFT function cannot be done
verneinvirgile
6-Contributor
I am using Creo Parametric 5.0 5.0.5.0
I made a video of the issue
https://we.tl/t-sVx4DpoAdx
Here are the errors that I faced
The function cannot be achieve
tbraxton
(To:verneinvirgile)
Since your part is created using an educational license, most here will not be able to open it. I built a model based on the video.
Swept blend works as I would expect it to for this shape. I suspect that your sweep trajectory may be the issue. Try to locate the proximal and distal ends of the trajectory within the sections and not on the boundary.
Blend trajectoryBlend trajectory
Involute Development, LLC
Consulting Engineers
StephenW
(To:verneinvirgile)
I can't imagine you will get many clicks on that link. You will either need to upload the video to the community or maybe youtube.
thank you for this advise , it's done !
tbraxton
(To:verneinvirgile)
And it works :
thank you very much
BR
VV
