Simplified Representation by Part Appearance
NathanAbplanalp
8-Gravel
I'm looking to create a simplified rep. based on part appearances. Ideally I'd like it to be an automated selection process. The simplified rep. would populate based on appearance name.
Is this possible?
I explored using rules & conditions inside the simplified rep. view manager, but could not find an option for "appearance."
Any help, guidance or ideas would be greatly appreciated. Thank you.
Hello @NathanAbplanalp
This approach, as formulated in your question, is currently not part of Creo Parametric capabilities for the following reason:
  1. Rules for Simplified Representations (documented in Help Center Here) are always based on the outcome of a query in Search Tool
  2. And Search Tool (documented in Help Center here):
    • can do queries on "geometries" for instance (Zone, Distance and/or Exterior Components)
    • but cannot use appearances (not documented in Help Center as possible entries of the Search Tool) to build a query
That said, as alternate approach, you may consider to approach this with materials where appearances are preconfigured in parts. Better than a long explanation, I registered a little movie for you to show how this can be achieved.
If not clear, feel free of course to get back to me with a reply to this post.
Serge
Thank you, Serge. I have watched the video. I'm hopeful this will help me achieve the desired outcome. I will give this a try. Thank you.
