I have created parts with multiple features.Placed in simplified repesentaion.
But in drawing views-Properties-view states-simplified representation is deactived.How to activate it ?
Hello, you have to set the required Simplified Rep. Do this by selecting Drawing Models from the Layout tab, then select Set/Add Rep, select your Rep, job done.
John
But I placed views first done dimesioning.
Now to follow this process I need to delete views and then set the Simplified rep.
Is it possible to set it from views properties.
Ah!! then i think you may have a problem. You can set the Rep & add new views, but i don't think you can you force a Rep on an existing view. I thought a work around might be to create a new view, with the Rep you want, & move the dimensions you have on your existing view to the new view, but the system won't even let you do that.
John
