Hello everyone
I have one quary that suppose i have a part and its drawing is already available to me, now in part if i create simplified representation and i want to change the representation of the views of already created drawing it is not happening, the simplified representation option is showing in disable mode. is there any option to make it enable in already placed views....
regards
nimish
From the help center:
Using the Drawing Models menu, you can create assembly and part views using simplified representations. You must specify the simplified representation before adding a view. You can add multiple views of an assembly or a part, each of a different representation, to a drawing.
When working with part drawings, the simplified rep must be set in the drawing models menu before you create the view.
Nimesh,
Check the article at https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS38390
Currently Simp rep will remain inactive in part drawing, however it may enhance in Creo 4.0.
it means after placing views in drawing i cannot change the representation of the model in drawing
Yes, after placing views in part drawing, rep cannot change.
In the past this option was called Assembly Simplified Rep. Although the description has changed the functionality has not. The option currently is only used to change assembly simplified reps.
