Simulate Reality
DenisJaunin
Simulate Reality
Do you know where it would be possible to retrieve the file from the example of the staple that folds into reality Simulate, page 4, in the attached document.
Cordially.
Denis
http://www.3hti.com/wp-content/uploads/documents/Top-10-Reasons-to-Upgrade-to-Creo-Parametric.pdf
I added a better picture of the folding of the clip.
If the file was available, it would be interesting to adapt the application.
Cordially.
Bonjour,
je ne vais pas vous êtres d'une grande aide, mais le plus simple serait peut-être de reconstruire l'assemblage en vous basant sur les images disponibles. (The easiest way could be to design an assembly by yourself, based on these pictures)
Cela vous permettrait de plus de tester les différentes fonctionnalités de Pro/Mechanica(Simulate). (This will allow you to try Pro/Mechanica possibilities)
