Simulate adhesion between rubber and plastic?
I have received a task of simulating a difficult scenario.
Rubber (Elastollan 1185A) is over moulded over a plastic part (PBT GF20).
The rubber stays on the part due to adhesion between the contact region.
My task is to simulate the situation where the rubber peels off from the plastic part due to pinching force applied on the rubber.
I am unable to comprehend how to simulate this with Simulate 2.0?
Also the available material data for both the materials is limited (from vendor's material sheet): UTS, Poisson's ratio, Breakage Strain, etc.
For both materials I have the stress-strain curves: plastic being elasto-plastic and rubber being hyper-elastic.
I have already created materials in Simulate for the same but dont know how to proceed further?
Also is the co-efficient of friction between the 2 surfaces required? I do not have this...
Any guidance in this activity would be very helpful.
