Size Matters
wfalco
Size Matters
All,
What is the smallest (filesize/intensity) export from Pro/E to Solid
Works? I've tried shrinkwrap with not so great results. I thought there
may be a file type that I may be overlooking?
Wayne
wfalco
(To:wfalco)
I should add:
I originally imported the file into Pro/E because someone who needed the
file had issues importing. Maybe memory? So I suggested that I try to
import and export something lighter. My machine is loaded with memory.
Even so, it took quite awhile for it to import. It is a vehicle. It has
MUCH detail....all the way down to the tire treads.
WF4
