Sketch and views visualization order
fmas
2-Explorer
Anyone knows how to change the visualization order of a sketch overlapped on the geometry?
By default the geometry is shown over the scketched arrows, but i want the opposite.
Anyone knows how to do that?
I'm working with creo / pro 5.0
7 REPLIES 7
MartinHanak
(To:fmas)
create arrows as solid features and place them above model geometry.
MH
Martin Hanák
fmas
2-Explorer
(To:MartinHanak)
Hi Martin, thanks for answering,
When you say solid features, do you mean create parts with the arrow shape on the 3d model?
MartinHanak
(To:fmas)
Hi Fernando,
you have understood my reply right.
MH
Martin Hanák
fmas
2-Explorer
(To:MartinHanak)
Thanks Martin, but I can't fill the 3d model with arrows...
StephenW
(To:fmas)
Another possibility would be to sketch an arrow part file and the cross section it in the model. You can add x-hatching in a closed sketch by going to sketch setup, then the properties tab.
StephenW
(To:fmas)
This is a standards issue. Solid geometry always takes precedence over leaders, dimension lines, witness lines, etc.
If you print this in monochrome, it will not matter.
I personally would take a screen shot of the geometry and add arrows in a secondary program.
fmas
2-Explorer
(To:StephenW)
Thanks Stephen; the drawings are in color, but I'll take into account the last solution.
