Hi!
I have a question. I had never used Creo Pro/program before, but I got an interesting work.
I watched some tutorial video on youtube about what is it.
I have 5 sketches, but I have to use only one in assembly. Firstly I would like to use a dialog box and I would like to select a sketch and after that I would like to extrude this sketch, but later if I select another sketch in dialog box then the program extrude the new sketch.
I would like to ask for some help on how to start my work.
I hope my description was understandable.
Thanks in advance for your help.
I use Creo Parametric 8.0
Hi kalm0079,
Thank you for your question!
However, I would encourage you to review your post and see if there's anything else you could add - screenshots, for example.
