Sketcher Construction Line style
dgschaefer
In Creo (all versions, as far as I know), construction geometry in sketcher is a very faint dot font.  It's very hard to see and I'd to change it, is that possible?
I did some digging, and found this thread which led to this tech support article that does, in fact, show how to change the line style from DOTFONT to PHANTOMFONT, however it also changes all the sketcher colors to pre-Wildfire, which I don't want.
Is there way way to change the line style only?
LinkedIn
jmorgan
(To:dgschaefer)
I want to do the same thing.  Has anyone found a fix for this?  Some of the things PTC does make no sense.  The user should be able to change color, thickness and font style for all line types.  Everyone does not have 20/20 vision and some are color blind.
