During a recent PTC/USER Technical Committee meeting we had a discussion about the Sketcher Intent Manager.
This discussion made me curious as to if there are still users that find the need to turn off the Intent Manager, which is why I am writing.
If there is anyone that still turns off the Sketcher Intent Manager, can you please respond to the questions below?
1. What are the circumstances that causes you to turn off the Intent Manager?
2. If you are importing data, is this done as a "normal" sketch with the intent to drive geometry with that sketch, or as a cosmetic sketch where you are probably not looking to drive geometry?
Please note that the reason of "Because it is annoying", is NOT specific enough.
In order to present the need for this, I need specific use cases (models and/or written) in which users turn off intent manager and still want to do something non-cosmetic with the resulting sketch.
Thanks....
Joel Nelson
PTC/USER Sheetmetal TC Chair
I disable the Intent Manager in order to access the Adv Geometry tools to join multiple datum curves into a single curve.
Thanks...Brian
I don't do it very often but once in awhile intent manager just will not accept my sketch and dimensioning scheme. I am usually able to get the same geometry, constraints and dimensions to regen with the intent manager turned off. So please, never remove the ability to turn off the intent manager.
The attached pic is one blend feature that required intent manager to be turned off. Note that the screen shot is just picking the feature and selecting modify. It is a blend feature with 4 cross sections so you are actually looking at the dimensions for all 4 sections at once. I had to turn intent manager off for each each section even though section 2 is exactly the same as section 1 and section 4 is exactly the same as section 3. I did a save & retrieve for the repeat sections.
Joel
I work primarily in tool design and almost don't remember the last time I turned off IM. I do however disable constraints as I sketch.
Steve
WF-2 M080 FlexC
Win XP SP-2
Dell PWS 690 3GB Ram
Nvidia Quadro FX4600
