Sketcher "Point on Extension Line" Constraint
M.Shuler
8-Gravel
During sketching I often run into this constraint and I would like to disable it, the problem is, this one is not in the list of constraints in the options menu. A google search has not been fruitful.
I do not want the points of a box I am sketching to snap onto other references, I know I can right click to disable it but would prefer to not have to deal with this constraint at all.
Any tips would be appreciated.
kdirth
(To:M.Shuler)
Holding shift disables creation of all constraints not locked.  💡
5 REPLIES 5
kdirth
(To:M.Shuler)
This will work for sure.
If there is no way to completely disable this constraint I will mark this as the solution, but it's more of a workaround IMHO.
kdirth
(To:M.Shuler)
Try config sketcher_point_on_entity_constr no.
Well this did work, but now I cannot start a line or rectangle on any reference haha.
I see in this config option there is mention of an "Intent Manager." I am going to look into what this is a bit more, maybe the answer is there.
kdirth
(To:M.Shuler)
You might want to play around with sketcher_snap_sensitivity.  Affects the sensitivity of all intent manager constraints.
