Hi, I have no clue exactly what constraints you have provided. as per your posting, I understand that, a cylinder tube is assembled with a plate , by means of screws. I had requested to establich a rigid connection, because, when an internal pressure is applied on the surface, then when a rigid connection is established between two surfaces, then load will be transmitted from the cylinder surface to the plate, and in turn to the fasteners. With this we can achieve good results. In order to find out the stresses then we have to have a measure (in mechanica) option given to the screw surface, then when you check the RPT file, you will be able to see realistic results. If you can let me know you mail ID, I can send you the suggested technique to use fastener connections. I don't know where to upload in this forum. Shekar[/url]
