Solution: Find in a mapkey
davehaigh
User Error! I'll admit to not having used the find tool much.
When you pick Tools, Relations, Feature, you get this menu.
[cid:image001.png@01CAFCED.7DDD8A40]
The problem was that I thought once the feature was in the found list that it was selected. No, you have to pick >> too shove it over into the selected field.
[cid:image004.png@01CAFCEE.27EFE690]
Once you've done that then you can add the local parameter and the relations. My mapkey now works unattended.
[cid:image003.png@01CAFCED.7DDD8A40]
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
davehaigh
(To:davehaigh)
Attached is the mapkey. The only problem I'm having now is it's not placing the feature in the footer. I'm picking that from the RMB menu, not sure why the mapkey is ignoring it.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Livermore, CA 94550
