Hello!
Is there a way to alphabetically sort the list of layers when importing an XML into creo cabling? See the picture below for an example. We use a lot of layers, so it's difficult to sort through a long list like this to find the proper one.
Thanks!
We will handle this small enhancement, but could you please move this to the ideas forum instead?
Creo Parametric Ideas - PTC Community
This way I will be able to keep you posted.
Hi @AH_10565398,
Thank you for your question.
Anurag
I had this same question! I think it will be fixed when they transition away from the Menu Manager (hopefully soon)
