I'm working on some project and I'm using CREO parametric 3.0. I'm having a problem to identify the spline method implemented in Parametric 3.0. Which type of spline equation used in CREO? Is it NURBS or B-Spline curved equation or other type of spline curves?. Does anyone know or perhaps give me the link to answer this question?
thank you in advance.
regards.
You can check by removing creo_parametric_customization.ui
By default it wikll be under <User>\AppData\Roaming\PTC\ProENGINEER\Wildfire\.wf
Thanks for some reason it has appeared back!
You may close the post by accepting your comments as solution.
Mine does this all the time. All I do is activate a component, then reactivate the top level assy. The toolbars return to normal. This has been in issue for me since Creo 3.0
