Split BOM table to same sheet.
ptc-1798826
1-Newbie
I have a very long BOM table, I want to split it side by side in same sheet. Regards, Vimlesh Patelia, India.
1 ACCEPTED SOLUTION
1. Highlight you BOM 2. Select 'Table' from the top menu then 'Paginate' 3. Select 'Set Extent' 4. Select row on the BOM that you want to be the last row shown. 5. Select 'Add Segment' 6. Select where on the drawing you want your second part of your BOM to be. First you will select where you want the bottom left corner to start at. Then you will select where you want the top right corner to be at. Be sure to select far enough away from your original point so that it will generate enough rows for all of your items.
4 REPLIES 4
That works! Thanks Nathan!
Thanks for the help... it worked easily...
Jus t was wondering what is the process to Split BoM to Next sheet ?
See https://www.youtube.com/watch?v=HbL2lGR6_BI
The default is to create new segments on the next sheets after you select a point for the table extent.
