Using Creo Elements/Pro 5.0 M210
Is there a way to make a draft like shown on picture ?
If i use front plane as draft hinge for splitting. My sketch diameter d1 changes as d2
I want to keep d1 diameter dimension fixed and draft until up to the front plane and then draft down to the d1.
Not sure about Creo Elements/Pro 5.0, but in Creo 2.0 you can:
1. Before selecting anything, go to the "SPLIT" tab and select "split by split object"
2. In the Split object box, "Define" to sketch a line that represents your split location
3. On the "References" tab, select the surface(s) you want to draft
4. In the Draft hinges box, select both top and bottom surfaces of the cylinder, using the CTRL key.
5. Set the pull direction.
6. Set the Side options to "Draft sides dependently"
Hope this helps.
I think the easiest way to do that would be with a revolve. As you discovered, the draft hinge defines where the size of the drafted surfaces remains the same. I supsect that you're actual model isn't this simple, however.
I can come up with other alternative, but they'd be many more features.
Hope this helps.
You cannot select more than one draft hinge surface, I checked both WF4 & Creo 2.
You can use your method to draft one end at a time by selecting "draft first [or second, as appropriate] side only" and then drafting the other side in a separate feature. It's going to be hard to get the center to line up, if that's important, unless the cylinder is symmetric about the FRONT plane.
Here are a couple parts that I tried, both Creo 2.0 and WF4.
Well I've been doing molded parts with Proe for over 17 years and I just learned something new.
I initially selected my draft surfaces first. If you do, you cannot select multiple draft hinge planes until you select "Adjust angles to keep tangency" in the "Angles" tab:
I went back and looked at your instructions more carefully and tried again, defining my split sketch first and it worked fine. Ironically, it did not require selecting "Adjust angles to keep tangency".
This was WF4.
Neat trick, thanks!
Don't feel bad. One of our designers found this by accident after some "happy clicking".
Makes you wonder how many other helpful tools are hidden in the code that few people know about.
What's frustrating is that if you start with the draft surfaces, as seems to be the expected workflow, it simply isn't possible.
I agree, there are likely many helpful tools buried in there somewhere. Heck, some aspects like IDD and ISDX have interfaces that seem to be designed to prevent you from discovering things.
