It's been a while since I have done modeling in CREO. What's the best way to model square tubing? I thought there used to be a feature that you could extrude a line with a thickness to get simple square tube. I am just trying to sketch up a simple weldment bracket, and I don't want to put a lot of time into the modeling. It's not necessary.
Thanks in advance.
Extrude a thin protrusion is what you are looking for.
Bingo! That's it. Thank you.
You can use the Framework extension to get your tube size and length against a single line.
