Does anyone have any Dowel Pin Hole charts they can share? Unless I use a diamer that matches a standard threaded hole chart, I get an error that IFX cannot find the hole. Since there is no thread involved, I'm not quite sure how to configure a dowel pin hole chart. Dowels have alot more different thread diameters than the regular threaded hole charts.
What is the most efficient way to add these holes for use in IFX?
the most important thing is, that you have to add ALL existing dowel pin diameter to the ifx_pin_data.cfg file.
Then there are two posibilities to get a hole chart for a dowel pin diameter.
1. Use the attached PIN*.hol hole charts and set the IFX Options PIN_THREAD_SERIES_* to this values:
2. Use your own hole charts.
