Hello, I am trying to export my Pro-E file as a Step file. I can export my model as STP just fine but when i import the file, there is my model, and half of it covered by a triangular block.
I can simply remove this block but is there any way i can export the file so that this block is eliminiated to begin with?
Any comments/ suggestions would be great
thank you
Tools
Options
Find
Type in intf and then the system will list all of the configuration file options that begin with intf. This is where you could choose the intf_out_blanked_entities and set its value to no.
Apply
For future reference.
This seemed to solve the issue.
Thank you for your support!
I've had this problem before. The save-as is exporting things that are hidden.
You might be able to use the "Customize Layers" status in the dialog to have it "exclude content" based on layers.
thank you for your response.
I followed your instructions into customize layers.
There are two options
ignore
or
skip
The default is set on ignore.
i tried with all the options on skip but no luck...
Tools
Options
Find
Apply
You must be using a different version. I was looking in Creo 2.
Thanks for the tip in the config.pro. Definitely need to add this to my default configs.
I did try the layer filtering in Creo 2 and it did work. Seems there were some upgrades done to the interface.
