I have a problem with identifying what is wrong with the Intersection paths for Sweep:
It seems like an easy fix but I need some fresh eyes to catch it.
I opened it in Creo+ and chain 1 is an edge on the bottom of the board. You must have accidentally selected it. I changed it to the curve and the result looked better.
I also tried creating a similar feature with surfaces
Thanks a million @kdirth, the previous one is my preferred way. It works fine now, thanks!
