So I am trying to name a 2-D section for one of my drawings on Creo 3.0 and out of nowhere I can only type symbols, but if I hold the shift key I can type upper case letters but when I try to save the section as "A" it says illegal characters entered. Also, instead of a one line blinking cursor when typing it is a thick black box. I have tried creating a new drawing but it does the same thing. Any help would be greatly appreciated.
Sounds like you hit CTRL+A combination; that will switch to input the "special symbols". For example, CTRL+A, then small case 'n' will put in the diameter symbol (Ø).
To exit this mode, you press CTRL+B (but it seems ESC key will also work). At least this is how it is working in Creo 2.0.
On a related note: once, I got into an input mode where characters were being typed in from right to left. Does anyone have an idea what key combination I pressed to get into such mess?
Confirming the original issue was about Ctrl-A where Shift-A was intended.
On the related note: I don't know how exactly you got there, but where you got was having specified the input language as Hebrew. Hope that helps!
Never knew about this! Is there a complete reference of all the keystrokes somewhere?
Look through this thread:
Here is another one:
Note: it is actually required to use lower case letters - i.e. to insert the "to depth" symbol use: CTR+A + "x" + CTRL+B
