Security Alert Log4j Security Vulnerability. Click here to know more.
Summary: Converting assembly units
c_ochitwa
Thanks for all of the responses. The best solution was to change the assembly units, then select Aplications->Mechanica and it will ask you to convert all units to the assembly units. The only drawback is that family table instances will not convert, and the generics will need to be converted individually. I may try the Spekan batch found here: http://www.spekan.com/innotiv/index.php?mnu=dwnl&sub=batch. It should help me to quickly convert the generics, but I haven't tried it yet.
Once again, thanks for all of the responses.
Original Question:
Hello all. I am wondering if there is any way to convert the units of an assembly from one system to another and have the all of the parts units change as well. Any time I use setup->units to change the assembly units then open one of the parts in the assembly, its units are still in the original system.
Cory Ochitwa
Yorkton, Saskatchewan
cochitwa@sasktel.net
0 REPLIES 0
