Summary: ProE Install from downloaded .zip file without cutting to CD?
ckg
Thanks to all who replied, it seems that the best way to install from downloaded .zip files is to extract all the .zip file contents to the same folder, allowing overwrites where prompted.
Then you run the setup.exe file and it will install ProE without any CD change prompts. Just tried this on WF4 M140 and it works perfectly.
Best regards,
Chris Glenister
Mechanical Design Manager
Thermo Fisher Scientific
The Birches Industrial Estate
Imberhorne Lane
East Grinstead
West Sussex, UK
RH19 1UB
Tel (+44) 01342 310272
Fax (+44) 01342 315074
www.thermo.com
0 REPLIES 0
