Support of Adopt OpenJDK11
Sarim
I am using Creo Parametric - Release 6.0 (connected) Release 6.0 and Datecode6.0.3.0
We have been using Creo4.0 M120 and Creo6.0.3.0. We would like to know if Adopt Open JDK 11 is compatible with both the Creo versions.
Here are the errors that I faced
remy
(To:Sarim)
You need to know if if AdoptOpenJDK is compatible with Creo. When searching the knowledge base you will find this reference article : https://www.ptc.com/en/support/article/cs296661
In a nutshell the support of such equivalent to Oracle JDK is under consideration with no commitment at the moment.
To speed things up, filing a Product Idea is the better route.
Have you considered Amazon Coretto though?
Sarim
(To:remy)
Hi Remy,
Am still not clear with any of the Openjdk's.
No, I did not consider Amazon Coretto.
remy
(To:Sarim)
You are confused with Openjdk and did not consider Amazon Coretto.
You initially requested whether openjdk is compatible with Creo and the answer is that it is unsupported.
Is there something additional that i can do to help you?
