Suppress features without Pro/programa
MB_11089634
Hello Again.
CREO Frustration week 10 -
Just checking - is it really not possible to design "smart assemblies" were you can suppress parts/groups using parameters, unless I have access to PRO/program ?
I just happen to not access to this feature. Is it really not possible to do this using relations / parameters?
Thanks in advance.
tbraxton
(To:MB_11089634)
Do you have access to Program in part mode? To test this open a part and invoke the Program function.  I suspect the issue is that you do not have the AAX (Advanced assembly or equivalent) and that is the issue.
Without AAX you will not be able use Pro/Program in assembly mode.
Involute Development, LLC
Consulting Engineers
tbraxton
(To:MB_11089634)
You can build "smart" assemblies without Pro/Program but it will be painful unless you are using a Toolkit app or other API interface. It is highly unlikely that if you are using Creo to build parts/assemblies that you do not have access to Pro/Program. Pro/Program is part of the core feature set and AFAIK is included with all licenses. Can you explain why/how you do not have access to Pro/Program?
I cant access it because I get an error message saying I don't have a license.
 I don't have any options on the licensing it directs me to either under options.
tbraxton
(To:MB_11089634)
Thank you.
Yes, your are correct. I was not aware that the pro program from assembly was in fact the AAX.
Still frustrating that such feature comes at a cost.
Cheers.
