Hello members, is it possible to change appearance of Surface fill to other color?
I don't believe there is a way to set the color before creating the fill other than to give the model a specific color. After creating it, select the surface on the screen then select a color from Appearances.
yes, apply an appearance to it:
Thanks for reply, but when I select Fill feature and Go to appearance then Edit Model appearance is greyed out. Any other way to do that?
