This is something I've been complaining to PTC about since the beta release of Creo. I seem to be getting nowhere with this complaint, so I thought I'd ask the community if this is something you want.
Creo, doesn't let you add commands to the file menu. I want the ability to add mode independent commands to the file menu. One example is adding to the File, Print menu. But I would like to add to the File, New menu also.
[cid:image001.jpg@01CD0841.8A0D0D20]
Is this something you would like to do?
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
Hi everyone.
Even copying our creo_parametric_customization.ui from one machine to other, it won't fully work. One thing I notice that's for exemple is that our custom "icons" will be lost. all our custom buttons will appear with the funny yelow smile on the new machine...
In Reply to David Haigh:
The .ui file does not get read from the working directory. By the way there is no config.win in Creo 1.0.
(even though the help files talk about the config.win and the menu_def.pro it's not valid in Creo 1.0. I pointed that out to PTC this week.)
Your personal .ui file is stored in the cache folder.
Since my startup script is setting my cache folder to a non-standard location like this:
set PTC_WF_ROOT=%USERPROFILE%\pro\creo_1_home\PDMLink_Cache\PTC\ProENGINEER
My personal .ui is stored here:
%USERPROFILE%\pro\creo_1_home\PDMLink_Cache\PTC\ProENGINEER\.Settings\creo_parametric_customization.ui
If you want to be dictatorial, your startup script could copy a cooperate .ui to that location before starting Creo.
You can rename the .ui and place it in the loadpoint common files directory. For me that's here:
C:\ptc\Creo 1.0\Common Files\M030\text\creo_parametric_admin_customization.ui
Here's the information I got from PTC on how to merge two .ui files.
Title: How to merge a creo_parametric_customization.ui and a creo_parametric_admin_customization.ui into a single *.ui using Creo 1.0
Description :How to merge a creo_parametric_customization.ui and a creo_parametric_admin_customization.ui into a single *.ui Applies To Creo 1.0
* Ribbon customization is automatically save to D:\Users\<user>\AppData\Roaming\PTC\ProENGINEER\Wildfire\.wf\.Settings\creo_parametric_customization.ui
Resolution
* Automatically load D:\Users\<user>\AppData\Roaming\PTC\ProENGINEER\Wildfire\.wf\.Settings\creo_parametric_customization.ui at startup
* Manually load creo_parametric_admin_customization.ui from any location
* Move and rename D:\Users\<user>\AppData\Roaming\PTC\ProENGINEER\Wildfire\.wf\.Settings\creo_parametric_customization.ui to C:\Program Files\PTC\Creo 1.0\Common Files\M020\text\creo_parametric_admin_customization.ui
David Haigh
