Hi everybody.
To show the problem I have I'd need to upload the assembly. How can I do that?
I'm trying to make a pipe connection between two parts but when I finish with the sweeping the tube stays as green-dotted lines
You need to archive your Creo files to a .zip file and then post them, make sure to note what version of Creo you are using as well.
