Sweep on pipe array
AP_10190855
Sweep on pipe array
Hi everybody.
To show the problem I have I'd need to upload the assembly. How can I do that?
I'm trying to make a pipe connection between two parts but when I finish with the sweeping the tube stays as green-dotted lines
tbraxton
(To:AP_10190855)
You need to archive your Creo files to a .zip file and then post them, make sure to note what version of Creo you are using as well.
Involute Development, LLC
Consulting Engineers
AP_10190855
(To:tbraxton)
Here it is.
I'm workin with Creo 9.0
Thanks.
