I am trying to create a pattern of parts based on a part located at the center. I want 5 total parts, the center part and 2 on each side. I have been creating a direction pattern with 3 parts going opposite directions. When I first create the pattern, I get 9 total parts due to overlapping. I am able to select the dots on the center 3 parts and cut the number down to 6. I can not seem to find a way to get rid of the last extra part in the middle.
Any suggestions?
Tim
WF3.0 M180
Hey Tim,
It looks like you are trying to "turn off" the pattern parent feature. Not possible as far as I know.Plus I think this might be an invalid/unstable thing you are trying to do.
I think you will have better luck creating the pattern with your first featureoffest from thecenterline (2x offthe centerline) instead of placing the parent feature that on the centerline.
Dean
