System colors in WF5
dgschaefer
To elaborate, set the settings as you'd like, then save the syscol.scl
file (from the file menu within the System Colors dialog). Then you
need to add this to your config.pro:
system_colors_file c:\full\path\to\syscol.scl
That will make sure it loads automatically every time you start Pro/E.
Doug Schaefer
LinkedIn
1 REPLY 1
You can set the "Editable Area" under "User Interface" to change the Model Tree background to be the same as your other background.
The "Letter" button under the "Graphics" tab, sets the drawing text color.
As stated in the previous posts, you may need to tweak the other colors to display well with your desired background color.
[cid:image005.jpg@01CD9804.00C62850]
[cid:image003.png@01CD9803.FDEFAFC0]
Thank you,
Arnold Collett
Mechanical Designer
Space Launch System - Forward Skirt/Distributed Systems Design
Intergraph building 200 (48-10)
Bay 120, Cube 120-7
(phone) 256-542-6848
[cid:image004.jpg@01CD9803.FDEFAFC0]
