Currently, I see no way to have a "snap location' on the top right corner of my drawing that I can "snap" my BOM to every time I add one?
I want to be able to input "table from file", hit my mapkey (which has the appropriate xy coordinates), then it places it into the correct location. However I need the table to be placed using the top right corner but all my tables all get placed from the top left corner and there seems to be no way to change that?
My best method so far is to place my table, select it, hit my mapkey "F5", then click on my desired corner of the table, then my mapkey places it onto the correct xy coordinates that were included with my mapkey.
Not a huge workaround, but you should be able to change where a table gets placed from right?
If there's a better method that I'm not finding please share.
Thank You!
To achieve the precise placement of a Bill of Materials (BOM) table in a Creo drawing using a specific corner as the reference, you can utilize the `ProUITableAnchorSet()` function. This function allows you to set the position of the table with respect to a given anchor location. It is important to note that this function is applicable only if the parent of the table is a drawing area.
Here's a brief guide on how to use it:
1. **Identify the Anchor Point:** Determine the exact coordinates of the top-right corner where you want to place the BOM. This will be your anchor point.
2. **Use `ProUITableAnchorSet()`:** Implement this function in your scripting or mapkey to set the anchor point for the table placement. This will align the table based on the specified anchor location.
3. **Adjust Table Size:** If necessary, use `ProUITableSizeSet()` to set or adjust the size of the table. This is useful if you have a standard size for your BOM tables.
4. **Implement in Mapkey:** Incorporate these functions into your mapkey to automate the process. When you input "table from file" and execute the mapkey, it should place the BOM at the correct location using the top right corner as the anchor.
This method should provide a more streamlined approach compared to manually moving the table after placement.
This sounds like what I'm after. I'll give it a try. Thank You
When you make your original table, you need to specify the direction to set the origin location. To use the top right corner, select the second option, leftward and descending.
I'm using Creo 7 and have tried this method already with no luck. It did not change what corner it defaults to even though, to me, that makes sense.
I'll try it again.
Thank you. I was creating my tables a different way. This worked great!
