Taking views into Creo View
ML_2678909
How can I export the views that I have created in Creo4 via the view manager to a Creo View file?
Chris3
(To:ML_2678909)
I am surprised you are having this issue. I don't use the default recipe file, but I would have thought this is turned on in the default file.
If you are having an issue, then you will need to look at modifying your recipe file. The links below should get you to the right place.
https://www.youtube.com/watch?v=ukPG0gdbc28
https://ntrs.nasa.gov/api/citations/20140013296/downloads/20140013296.pdf
