I have an assembly template that has some parametrization, developed with AAX in assembly level (I belive that has something created in Pro/Program in assembly). Right now I only have available CREO Essentials license. My question is, can I use that template in my license? Will work correctly with all of the parametrization developed in AAX? I'm only prevented to edit the parametrization created in pro/program, Am I right?
In such cases, Application doesn't allow modifications without required license. Rest should be fine.
So all the parametrization developed with AAX should work?
yes
