The dimension display is set to retain 1 decimal place, but the actual dimension is still an intege
EF_8712258
I am using Creo Parametric - Release 6.0 (connected) Release 6.0 and Datecode6.0.6.0
The dimension display is set to retain 1 decimal place, but the actual dimension is still an integer
Translated with Google translate by Iuliana Nuta, 11 june 2022
kdirth
(To:EF_8712258)
the drawing options control the display of leading and trailing zeros.
Drawing options settings:  File>Prepare>Drawing Properties and select "change" for Detail Options
  • dim_trail_zero_max_places may be limiting the trailing zeros - set to "same_as_dim"
  • Lead_trail_zeros may be preventing trailing zeros - set to "both"
Dale_Rosema
(To:EF_8712258)
Are you metric or English units. I think metric standard is to drop the zero after the decimal.
https://www.engineersedge.com/engineering-forum/showthread.php/3873-ASME-Tolerances-Dimensions-and-decimal-places
