The green line and the blue line are displayed together. I used the fixing move and changed the parts, but the line appears both before and after the move. I converted the file to STEP format, and the STEP file still shows the lines. I tried changing the layer tree, but both lines are on the same layer, so I couldn't delete one line. Please tell me how to delete the line.
the blue line could belong to the curve, Try hiding the curve.
Thank you for the reply. The part is on the model was slightly inclined, Now the blue line has gone.
