The "branch" command does not allow me to select the line to connect the tubes
Jonathan_Felipe
The "branch" command does not allow me to select the line to connect the tubes, what could be happening?
Hi Jonathan...
It appears you're trying to "branch" into the same pipeline you're already running. You need to branch into a DIFFERENT pipeline. Start a new pipeline and route a small piece. Then you will be able to connect to it using the branch command.
Thanks!
-Brian
Hi Jonathan...
Thanks!
-Brian
Hi Brian
Your comment helped me a lot, I did exactly what you suggested and it worked perfectly
