To show Compression of spring in creo modelling
Rohit_Rana
i made helical spring in creo 11.0 .
i want to show compressed spring in creo modelling. how i can?
Why don't you search on these forums for "spring" or such?
You'll find lots of entries like this one:
https://community.ptc.com/t5/3D-Part-Assembly-Design/How-to-model-a-coiled-extension-spring/m-p/919133
Modeling a spring is a bit complicated, especially if you want it to be adjustable in length based upon the amount of compression. But, once you've got a model, it's very easy to re-use it for different sizes and spring conditions.
kdirth
(To:Rohit_Rana)
If the model is created in the right way, Flexibility can be used to change the length of the spring in an assembly.
kdirth
(To:Rohit_Rana)
Here is an example created in Creo 4.0.  Not saying it is the best spring example but will do what you are asking.
Relations are used to define many of the dimensions.  It is also setup with predefined flexibility so that, when you add it to an assembly, you will be prompted to use flexibility.
