As most of you do, you have a table, or a note, in your drawing formats thatlists the tolerance for the particualr part, assembly, etc.. Is there a way to create a table that pulls in the values that are, either set with the ISO tolerance tableor the values that are on the screen that you can change. Fro example, if I change the ISO tolerance from medium to coars, the table will update.
Thanks in advance for any help.
Tim Wells
