In Creo 8.0 part mode, when attempting to go into a dimension to add a tolerance, the entire tolerance section is grayed out. Is there a setting that needs to be changed to enable it? Did not have this issue occur in Creo 6.0.
you have to set TOL_DISPLAY YES option in config.pro file
-OR-
-OR-
That worked - thanks!
This does not work in Creo 9
Check this out, it worked for me in creo 9.0.
