Tolerances in hole tables
ccire
7-Bedrock
I have a part with many holes, some with plus-minus tolerances, others with H7 tolerances.
I can't find a way to show these tolerances in the hole table.
Anybody knows how to do this ?
Thank you !
Eric
ClintWalton
(To:ccire)
Hi Eric,
From the following document, this does not seem to be a functionality though it does suggest a workaround.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS158230
ClintWalton
(To:ccire)
Hi Eric,
The workarounds in that document are extremely poor. Workaround 1 is non associative and so I would not consider using. The second workaround is only good for feature parameters and not model parameters and so I can't see how that is any better.
Thinking about this further, this Product Idea has in effect been closed as Answered which it has not. You have mentioned workarounds which as far as I am concerned are not feasible workarounds. I would like to see this put forward as a Product Enhancement.
