Tool in CREO to create a sheet of mass properties of all the parts in an assembly?
CL_10387432
2-Explorer
I have a large assembly filled with many parts. I can use the mass properties tool to select each individual part and retrieve the mass properties that way but I was wondering if there was an easier method or tool that could accomplish populating the properties for each part quicker.
2 REPLIES 2
BenLoosli
(To:CL_10387432)
If you have the mass property in each file, like weight, you can create a repeat region table that can be populated with the part number, description and weight.
Chris3
(To:BenLoosli)
@BenLoosli 's answer is correct if all of the mass property parameters are up to date. If you don't have mass_property_calculate set to automatic or check_upon_save chances are some of your models don't have the mass property parameters updated.
In that case you can run Analysis -> Mass properties with the config mp_calc_level all_models. This report will not give you titles or other parameters that the repeat region will though.
