Hi all,
By using "&weldasm.totallength" we can show the total weld length in any table on DRW. But we need to use similar code in ASM parameters.
I tried to use "WELD_LENGTH" parameter of each future in the releation. But when I try to use the future parameter in releation it gives as "WELD_LENGTH:FID_702:3" specifically with FID. I can't use because the number of weld future in each file will be different and the location of weld future will be different.
If I successed to assign total weld lenght to any parameters I will sign as designated and will send to Windchill. Then I will prapare a query builder report which inludes total weld length of CAD Documents.
Do you have any idea. It can also be a solution with mapkey or ModelCheck ...
Best regards,
This may not be possible without the use of Toolkit API. See this article for details.
https://www.ptc.com/en/support/article/CS154928
Thank you tbraxton.
I have disappointed when I read the article.
It is very interesting, We have the value on drawing but we can't use it on solid w/o Tookit API.
Best regards,
Yeah, another example of why this software should be called Creo (mostly)Parametric.
Feel free to post a product enhancement idea here.
