Community,
Is it possible to transfer or copy a table from one drawing to another (not sheet-to-sheet)? Thanks in advance.
With a little more research, I found out that you can save a Drawing Table (.tbl) and open it back up in a different drawing. But I could not find a way to copy-and-paste it from one drawing to another. So saving the Drawing Table is all I really needed, same as transferring it. The save table icon will not activate until the table has been selected.
