Translation Pro-e drawings to Acad format
ptc-2231760
1-Newbie
I need submit drawings created in Wildfire 5 to client in Acad 2010 format. How I can eliminate usually few dimensions style in in translated drawing, setting layers type and colors to few (not all 255), etc. Most of this correction I am doing manually. Any advise?
2 REPLIES 2
search for dxf_export.pro on your hard disk. Open the file and edit as per your requirement. set "dxf_export_mapping_file" in tools>config to the newly edited file. That should do the job. [/quote]
Thanks Kamal!
