I will like to in a table on a format having the PTC_WM_CREATED_BY shown, but only the initial.
Can I on my format in the Repeat region use a relation to truncate this parameter, I have tied the relations in the Repeat region menu, but can't get it to work.
Allan,
here is my "procedure":
MH
Allan,
is the following example describing correctly your need ?
PTC_WM_CREATED_BY="Martin Hanak"
PTC_WM_CREATED_BY_TRUNC="MH"
MH
Martin,
not really.
I have in the filter "&mdl.param.name == PTC_WM_CREATED_BY", and that give me the full name.
In the relations I have tried "truncated = extract(mdl_param_value, string_length(mdl_param_value)-10, 3)", this give not error, but not change anything. If I use PTC_WM_CREATED_BY, comes an error "PTC_WM_CREATED_BY is unknown".
What shall I put the filter and in the relation?
Allan
Allan,
below written procedure is related to my data created in CR2 M070.
MH
Martin,
I can get your description to work on a drawing, but on a drawing format then I will create the relation my parameter is not known. And therefore I get an error. How can I fix this?
Allan
Allan,
MH
Martin,
Thank you it's working.
Allan
