The only way I could fix this is to go into AutoCAD and trace over the original drawing with splines, lines and arcs to reduce the number of elements. I had to "explode" it first. Delete all the original geometry and then reimport it as fewer elements.
Initially, I tried the "Select" option but I couldn't line up the parts of the sketch perfectly; so, that idea was a "non-starter".
I don't know how to turn off intent manager.
My work-around is to NOT import directly in to sketcher.
I import in to the part directly. Then I can see the sketch, no worries about resolve mode or entity count.
I will the use the import edges as reference or whatever other purpose I need.
Strongly agree with this. I've gotten system layouts and facility drawings that we wanted to use to sketch stuff in Creo and it never works. The line counts in a drawing from, for example AutoCAD, are extreme. The import always chokes to death on all the entities.
FYI, if you need a cosmetic sketch, not a regular sketch, then you can activate "under-constrained mode" under sketch-setup fly-down. That will basically turn off the intent manager (for the cosmetic sketch)
